Markinportland
Sep 19, 2016Aspirant
How far away can you place the Orbi Satellite?
I have a detached garage with a guest apartment above. It sits about 80 feet from my existing Comcast modem and Apple router in my 3500 SF house. I have tried two Netgear extenders with poor results....
- Sep 20, 2016
Hello Markinportland
Each unit can cover up to 2000 sq feet this will vary based on your environment. Also later on when we are selling individual satellites you can have up to 3 satellites with the one base.
DarrenM
itGeeks
Sep 28, 2016Apprentice
O good glad to here it, The fact that I am punding Eithernet backhaul and its getting borring is a good thing, That means I am beeing heard and could make Orbi even better. On closing I will not stop pounding this much needed support for Eithernet backhaul that both Eero and Luma have becouse I want Orbi to be the best in this category and I have a need for 5 locations for this and I dont want to settle.
peteytesting
Sep 28, 2016Hero
you might want to go over to smallnetbuilder and have a read of his latest testing called mesh wifi mashup
http://www.smallnetbuilder.com/wireless/wireless-reviews/33020-mesh-wi-fi-mashup
very interesting reading
netgear kn ow all about the want for ethernet support and have said they will look at it but no eta along with actual mesh setup and usb support and many other things on the list and at this stage its all TBA
- 06470Jul 24, 2017Aspirant
So the Orbi 3000 is not going to allow me to use my wireless devices down by the lake, 175 feet away, where people like to congregate. Twice I've sent an ethernet connected apple airport to do the job in the boat house down there and twice lightening has put an end to that option. So I would like a signal ffom inside the house to reach there. Anyone have suggestions.
- peteytestingJul 24, 2017Hero
at that distance you would have to have the orbi router and sat in line of site of each other
eg orbi router at a window facing the boathouse and the orbi sat in the boathouse at a window facing the main house and then you might get lucky
175 feet isnt that far in open space but if you have the orbi router in the middle of the house the signal will need to get out b4 it can tackle that open space
So its the wwrong equipment. Is there such a thing as an antenna so end out a signal from the house
sure its called a point to point bridge systen with a wireless access point at the other end
something like
https://www.youtube.com/watch?v=4zKNIveuCxM
but it depends on how your last stuff got fried by lightning as its power related you still might get fried
its ether that or dig a long trench and bury ethernet cable in conduit and have a wireless access point at the boathouse
