tompkinss2's avatar
tompkinss2
How to disable or Access Control only LAN ports on Orbi Satalite
Can anyone tell me if it is possible to disable the LAN ports on a Satalite or even better to enable Access Control block, manual accept connections on Satalite LAN ports?  I have a Satalite that people could plug into and get to my internal network without passwords, vs guest wireless and I want to block them unless I allow the mac connection... if not how do I request a new feature?
  • Advanced --> Security --> Access Control is your only option then use Block All New Devices
    • tompkinss2's avatar
      tompkinss2
      But that blocks wireless and wired ports, I just want to block wired.
