armoredsaint
Oct 17, 2017Apprentice
How to hide my SSID?
I know you can hide the Guest SSID, but what about the main wifi SSID? I can't find it
also the guest ssid when you de-select, it hangs also...another glitchy netgear software
- DarrenMSr. NETGEAR Moderator
Click Advanced-Advanced Setup-Wireless settings there you can un check broadcast the SSID of each band.
DarrenM
- moutainravenAspirant
I do not see the option to hide main SSID in Advanced Wireless Settings. Only have option to hide Guest's
- st_shawMaster
Unless you have old firmware or something, it's there. Read Darren's instructions carefully and look again.
the main question here is why hide ssid in the first place , its not a security setting nor is it good betworking practice
have a read of
http://www.zdnet.com/article/the-six-dumbest-ways-to-secure-a-wireless-lan/
its the second on the list if that gives you a good idea
just securing with wpa2 is a far better option
pete
