Daniel-UK
Sep 25, 2020Apprentice
How to setup an Orbi system with Sky fibre broadband
Scenario 1) Using the modem/router provided by Sky that does NOT have brigde mode. ==> Using Orbi in router model will create a dual NAT problem. Using Orbi in AP mode will loose functionalities (e....
Mstrbig
Sep 25, 2020Master
The double NAT scare is very overrated. We have many installs where customers want 2 entireley different network setups with no issues ever. There may be issues with gaming devices not connecting to their game servers. But there are work arounds for that as well.
I would set your Orbi up as a router, (yes double NAT) and then test if you have any issues with devices. If not, you are good to go. If so you can change back to AP mode.
If you wanted to change out your ISP modem/router, you would have to contact your ISP to find a list of compatible modems.
- Daniel-UKSep 25, 2020Apprentice
Thanks Mstrbig for your answer although it doesn't look like you are familiar with Sky or other UK ISPs. None of them provide a list of recommended modems although they are now forced by OFCOM to allow other modems.
I currently have the double NAT that is generally ok but it does cause some problems - and I am trying to avoid having the Orbi in AP mode.
In regard to scenario 1) are you aware of any other solution or how to implement what suggested by FURRYe38 'to configure the Sky modem DMZ for the IP address the Orbi router gets from the modem' ?
In regard to scenario 2) I have now also a modem that works well with Sky (DrayTek Vigor 130) BUT I need a router that support DHCP 61 and it seems that Orbi does NOT :-(
However I can see in Basic --> Internet the following options:
DHCP Option Vendor Class Identifier String (Option 60): Client Identifier String (Option 61): Does anyone know if that could then work with Sky and what should I put there and also in the other configuration settings in that page?
Many thanks
- FURRYe38Sep 25, 2020Guru - Experienced User
Check the modems Mfrs support pages or user manual on how to use there DMZ or IP-Passthru features on there modems. This will help with the double NAT with the Orbi RBR in router mode connected to a up stream router.
- MstrbigSep 25, 2020Master
Daniel-UK wrote:Thanks Mstrbig for your answer although it doesn't look like you are familiar with Sky or other UK ISPs. None of them provide a list of recommended modems although they are now forced by OFCOM to allow other modems.
You are correct, I'm not very familiar with Sky. However, I find many 3rd party modems and modem/routers that have been reported to work fine with Sky broadband networks system, following instructions for adding mac address, username and password, etc.
A simple internet search turned up several that would fit your needs as well as tutorials and videos on how to setup TP-Link and other brands of routers, using skypass for the modifications, (http://www.ph-mb.com/products/sky-calc). This should allow you to set it up so your Orbi can be in router mode. I cannot guarantee any information as I have no way to test.
FURRYe38 Sky Modem doesn't have the option for IP Passthrough. The DrayTek Vigor 130 has.
Mstrbig you are absolutely right, there is plenty of documentation for many routers... except for the Orbi!
Hence why I am trying to ask for help to this specific community and in particular
1) does Orbi have DHCP 61 support?
From this post does not seem so https://community.netgear.com/t5/Orbi-AX/DHCP-Option-61-Client-ID/td-p/1918773
BUT from what I can see from the orbi configuration --> Basic --> Internet
as I posted earlier I can see "DHCP Option" Client Identifier String (Option 61):
so it does seem that now there is?!?
And looking at https://www.draytek.co.uk/support/guides/sky-fibre-setup-guide I am clear that in that field I need to put a string such as "aabbcc123456@skydsl|aabbccdd" where the first part is the MAC and the last is a pwd of my choice (this is the ONLY thing well documented over the internet altough not specific for the Orbi).
2) how should I configure all the other settings to work correctly with Sky Fibre?
Does your Internet connection require a login? I can guess it is Yes and then PPPoE. Then, should I put any credentials?
Internet IP address --> Get Dynamically
DNS --> automatically?
Router MAC?
Should I add any "VLAN ID Configuration"?
3) is there anyone out there that actually succeded in configuring Orbi as a primary router for Sky Fibre?
Many thanks in advance!
