Daniel-UK
Sep 25, 2020Apprentice
How to setup an Orbi system with Sky fibre broadband
Scenario 1) Using the modem/router provided by Sky that does NOT have brigde mode. ==> Using Orbi in router model will create a dual NAT problem. Using Orbi in AP mode will loose functionalities (e....
Mstrbig
Sep 25, 2020Master
Daniel-UK wrote:Thanks Mstrbig for your answer although it doesn't look like you are familiar with Sky or other UK ISPs. None of them provide a list of recommended modems although they are now forced by OFCOM to allow other modems.
You are correct, I'm not very familiar with Sky. However, I find many 3rd party modems and modem/routers that have been reported to work fine with Sky broadband networks system, following instructions for adding mac address, username and password, etc.
A simple internet search turned up several that would fit your needs as well as tutorials and videos on how to setup TP-Link and other brands of routers, using skypass for the modifications, (http://www.ph-mb.com/products/sky-calc). This should allow you to set it up so your Orbi can be in router mode. I cannot guarantee any information as I have no way to test.
Daniel-UK
FURRYe38 Sky Modem doesn't have the option for IP Passthrough. The DrayTek Vigor 130 has.
Mstrbig you are absolutely right, there is plenty of documentation for many routers... except for the Orbi!
Hence why I am trying to ask for help to this specific community and in particular
1) does Orbi have DHCP 61 support?
From this post does not seem so https://community.netgear.com/t5/Orbi-AX/DHCP-Option-61-Client-ID/td-p/1918773
BUT from what I can see from the orbi configuration --> Basic --> Internet
as I posted earlier I can see "DHCP Option" Client Identifier String (Option 61):
so it does seem that now there is?!?
And looking at https://www.draytek.co.uk/support/guides/sky-fibre-setup-guide I am clear that in that field I need to put a string such as "aabbcc123456@skydsl|aabbccdd" where the first part is the MAC and the last is a pwd of my choice (this is the ONLY thing well documented over the internet altough not specific for the Orbi).
2) how should I configure all the other settings to work correctly with Sky Fibre?
Does your Internet connection require a login? I can guess it is Yes and then PPPoE. Then, should I put any credentials?
Internet IP address --> Get Dynamically
DNS --> automatically?
Router MAC?
Should I add any "VLAN ID Configuration"?
3) is there anyone out there that actually succeded in configuring Orbi as a primary router for Sky Fibre?
Many thanks in advance!
- Haines17Jan 21, 2021Aspirant
so i believe the right set up would be no to require a login
then you can set anything at all in the username and password field for the option 61, as long as the character length, @skydsl and pipe | are there and in the right places.
this is from much frowning at the internet, then a purchase of a Nighthawk R1000 only to learn it not had the 61 option released into its Duma os FW yet, but the 500 has! hope it helps you! im interested in this too as am sending the hawk back as not waiting months for a release of FW, so may plumb for the Orbi instead if it works.
