Fahd64
Jun 16, 2019Aspirant
I need restore my Netgear Orbi original factory defaults our isp locked firmware update
I have Netgear Orbi RBK50 buying our Internet Service Provider they rebrand re software & re firmware update they old firmware in 2018 I need restore my Netgear Orbi original factory defaults Because I need official download firmware update
can I do restore getting official firmware update
Do you mean that you bought an Orbi from an ISP and that it came with customised firmware?
You may have to investigate the use of stuff like TFTP, and other "command line" tools, to write Netgear's firmware to your Orbi.
I haven't seen much mention of that around here. It isn't something that Netgear will support officially, so a search for third party sites might help.
Does your ISP have a user forum where you can talk to other customers?
- Fahd64Aspirant
michaelkenward wrote:Do you mean that you bought an Orbi from an ISP and that it came with customised firmware?
Yes Our ISP Ooredoo
I Don`t Know About This I need remove ISP firmware Put official Netgear's firmware beacuse i don`t can
what to do How i to doing
No We don`t Have
Fahd64 wrote:
I Don`t Know About This I need remove ISP firmware Put official Netgear's firmware beacuse i don`t canwhat to do How i to doing
You need to do some research. This is not the best place for that information.
how to hack orbi firmware - Google Search
This is not easy. I understand this stuff and would not want to try it without good reason.
It would be easier to stick with the firmware and complain to your ISP.
