Sweepr9
Jun 06, 2020Aspirant
iAquaLink and rbr40
I have had an orbi Rbr40 with multiple satellites for almost 2 years with no issues. I have an iAquaLink iq900 that has been wired directly into one of the satellites to connect. There have not been any issues until a week ago. I believe it corresponds to my firmware being updated but I’m not positive. The iAquaLink won’t connect anymore and the orbi doesn’t even recognize that it is wired in. Nothing else has changed with my setup and I’m at a loss for what to do to remedy the issue. Any help/knowledge would be very appreciated.
- tucsonticoVirtuoso
A little more information is needed to try to help you:
1) Which firmware is loaded?
2) Are the satellites and router on the same version?
3) What troubleshooting have you done so far, e.g., have you tried to power cycle the entire system and resync the satellites?
Ultimately, solving your issue may requre a factory reset of all of the ORBI components and a reconfiguring the system from scratch (not a backup config file).
Good Luck!
Has a factory reset and setup from scratch been performed since last update?
