P95357's avatar
P95357
Guide
Mar 02, 2025
Impossible to install Arlo Go2 camera on Orbi RBK53
The Arlo Go2 camera needs a phone with the Arlo app connected to 2.4GHz. The RBK53 won’t let me choose the network, and the phone always connects to 5GHz. I’m not sure if there’s a way to temporarily disable 5GHz to force the phone onto 2.4GHz for setup.
I tried the setup in the Arlo app, but the camera doesn’t chime when scanning the QR code, so I can’t complete the process. The camera worked before, but after the battery ran out and I charged it with a cable, it disappeared from the Arlo app and I’m trying to bring it back.
I already have two other Arlo Go2 cameras working fine.
Any help on forcing my phone to connect to 2.4GHz would likely let me finish the setup.
  • CrimpOn's avatar
    CrimpOn
    The original Orbi WiFi router (RBR50) has an option on the web interface to disable broadcasting the SSID on 5G.
    It is on the Advanced Tab, Advanced Setup, Wireless Settings:
    On the phone,
    • "Forget" the Orbi WiFi
    • Turn WiFi off and back on
    • Search for your Orbi WiFi
    • Enter password and Connect
    Only the 2.4G WiFi will be visible and the phone should connect at 2.4G
    After the camera is set up again, enable SSID broadcast on 5G again.
    • P95357's avatar
      P95357
      Guide
      Thank you. I found this procedure and tried it before posting. I unchecked the “enable SSID broadcast” in 5G, hit apply, logged out and restarted the router. With the phone procedure done, I put the Wi-Fi password again and it shows up listed under 5G in the Orbi app. Regardless, I tried the installation procedure in the Arlo app and the camera doesn’t read the QR code that is shown in the Arlo app so the procedure cannot be completed successfully. The app then leads me to troubleshooting steps and the very first item is to ensure the phone is in a 2.4GHz band.
        Your phone might still be using the 5Ghz band from your previous setup.  After you hide the 5Ghz SSID in Orbi, go into your phone and Forget the SSID connection (to make sure it forgets the 5Ghz band).  Then add it again (this time it can only see and use the 2.4Ghz band).  Now try setting up your Arlo camera again.
