Gellie's avatar
Gellie
Intermittent drops on 2.4ghz
So I noticed i'm gettign a fair amounts of drops on the 2.4ghz band on my Orbis. Not getting the drops on the Fios router. I have tried changing the channels(1,6,11) to no avail. The Orbi is in AP mode. Are the any changes that I can try? I moved my wirless phone away from te satelite.
  • Also I should mention that under advanced settings everything is enabled.
  • FURRYe38's avatar
    You may want to try and lower the power out put of the Orbi radios by lowing from 100% to 75 or 50%. Under Advanced Tab/Advanced Settings/Wireless Settings
    Not seen on Orbi AX.
    Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
      • FURRYe38's avatar
        Hopefully something will help with this. Keep us posted.
    • FURRYe38's avatar
      Wouldn't effect the RBR in AP mode unless the offending attacker new the IP address of the RBR while in AP mode.
      GeoffChesh wrote:
      Hi,
      Not sure if this applies to AP mode or not (apologies), but I have been experiencing drop outs due (I think) to suspected DoS attacks. Once I disabled that protection, the WiFi signal (on all bands) held up more reliably.
      If you are interested, he is the discussion link:
      https://community.netgear.com/t5/Orbi/Repeated-DOS-attacks-causing-dropped-connections/m-p/1851729/thread-id/80841
      Hope it helps
      Geoff
      • Gellie's avatar
        Gellie
        Thanks, one new thing im trying is to turn off the wireless on my router. Just using Orbi in AP mode. Maybe the to wireless singles were interfering with each other?
