bryanchuah17's avatar
Aug 31, 2020
Internet connection disconnect intermittently for sometimes
My internet connection disconnect intermittently sometimes. It disconnected for 3 sec and will automatically connect to the internet soon. May I know how to fix this problem as it already been a long time since I first use the mesh wifi on April this year.
  • FURRYe38's avatar
    https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
    Do you have just the one Orbi router or satellites as well? Is it the WIFI disconnecting or your Internet connection? How is your Orbi router connected to your ISP modem/router?
    • bryanchuah17's avatar
      bryanchuah17
      Tutor
      I have one router with two satellite. WiFi disconnecting intermittent for sometimes. For example, when I’m watching any movies (it can be surfing website too) with any devices, it will cut off the WiFi connection for few seconds and connect back within 10sec.
      • Mstrbig's avatar
        Mstrbig
        Master
        Who is your ISP and what equipment. (modem, router, ONT), did they provide?
        What is the current firmware on your Orbi device?
        What device is your Orbi router connected to?
        Have you changed the network cable connected from the ISP device to your Orbi router?
        Are your satellites wired or wireless?
