DCP4971
Sep 23, 2017Luminary
Internet dropping on Orbi V2.0.0.72
V2.0.0.72 was fine initally, but I'm not overly impressed with how it handles dropping internet. I suspect my ISP supplied router is periodically (and far too frequently) dropping it's connection for a brief period. When this happens, Orbi goes all angry and purple halo on us, which doesn't necessarily rectify itself when the Internet is back and the Orbilogin page goes awol - but the Satellite status page is still available.
Initially, I was resorting to power cycling the base, which was fine for a bit, before the Internet dropped the next time, but also found that by unplugging the inbound LAN from the ISP router, kicked things back to life.
That said, as it stands, I'm currently connected to Orbi, using the internet ok, but the base is still all purple halo..
Before V2.0.0.72 we had no issues, it was all very stable, other than an early conflict with our Sky Q boxes which used the same wirelss channel.
Am I alone in having such issues? It seems pretty poor releasing a firmware that's not overly robust imho..
- ElyLuminary
Why would you use your ISP's supplied router when you have the Orbi? if I was you I would just disable Wi-Fi on it and run the Orbi as the router, I suspect you have a Router/Modem combo from your ISP, just disable the router part.
Also you have tried updating to V2.0.0.74 on your Orbi? .72 is no longer the latest.
- DCP4971Luminary
Ah, the important bit that I missed.. Am using Orbi as my AP, the Cable modem is just the gateway with Wifi disabled - my suspicion is that this is dropping the internet and Orbi has been struggling to handle this.
I've installed .74 this afternoon, so seeing if that makes things more stable.
- ElyLuminary
Why use Orbi in AP mode though? Orbi is a wonderful router.
