apercele79
May 21, 2020Aspirant
Internet goes out every so often. Can I check whether it's my modem or my Orbi setup?
Several times a day, my internet goes out for literally a minute and then works normally as if nothing happened. But it's safe to say that it's super annoying. Am I able to check what the issue is, whether it's my modem or this AC3000 kit?
Glad that worked. Please mark your thread as solved so others will know.
Enjoy. :smileywink:
Is the Orbi system operating in Router or AP mode?What is the size of your home? Sq Ft?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?- apercele79Aspirant
Thanks for the very detailed reply, it ended up being my modem. I changed it that same day and havent had an issue since.
Thank you again!
Enjoy. :smileywink:
