Cody1966's avatar
Cody1966
Interuption after power surge
Model RBK 43
Just had a lightning strike with a power surge.
My computer shows no access.
The unit is solid purple.
Is there an easy reset?
The satellite units worked for several minutes and then they stopped as well.
  • FURRYe38's avatar
    Press in the reset button in back of the RBR and RBS for 15 seconds then let go. What for the top LED ring to slowly pulsate WHITE. With a wired PC, walk thru the setup wizard at orbilogin.com or 192.168.1.1...
    Use a paper clip unfolded to press in the button.
    • Cody1966's avatar
      Cody1966
      I used the a paper clip. Now the unit is solid white? Do I need to do something else?
