bsholbrook
Dec 16, 2016Apprentice
iOS devices
Running the Orbi formware 1.40.0.18 I've now experienced a couple of cases where an iOS device will infrequently get dropped off the network going from full signal to no wifi for upwards of 30 seconds...
Sevo123
Apr 07, 2017Apprentice
Just got the orbi rbk53 2 days ago and set up everything updated to most current firmware but wow signal keep dropping constantly! Netgear has to fix this ASAP and add ability go actually have these satellites be mesh and communicate with eachother. If not im going to velop linksys! - on side note netgear rep told me mesh capability is in works with firmware upgrade. But this wifi dropping is a disaster. And yes this is using a 7 plus. Smh fix this netgear
RustyShano
Apr 25, 2017Guide
I posted a reply to this in another similar iOS thread. Here's the link. Hopefully it works for you too.
