keeper88's avatar
Jun 04, 2017
iPad issues on Orbi
I'm reading a fair amount of issues with iOS devices on Orbi as I'm having issues with iPads intermittently not working.  Most times, they show full WiFi signal but can't browse Internet or do speed tests successfully.  I'm running the RBK40 kit with latest firmware on router (V1.10.1.2) and satellites.  Is this a known unresolved issue????
  • The ipad or IOS issue is knownand NG on working on it.  A beta version of FW ( 1.11.0.2 ) has fixed my older ipad issue ( ipad g2/os 9.3.5 ) and android battery draining
    • keeper88's avatar
      keeper88
      Guide
      Thanks TomMac.  How might I go about trying the beta version myself (is that available)?
      • DarrenM's avatar
        DarrenM
        Sr. NETGEAR Moderator
        Hello Keeper88
        I have sent you a PM
        DarrenM
  • Retired_Member's avatar
    Retired_Member
    Hey Keeper88, when the beta inevitably doesn't work look into the backhaul dropping issue mentioned in some of the other threads. That's your problem.
    • keeper88's avatar
      keeper88
      Guide
      Thanks Mr. Saget..  I just did a quick read of a couple.  When my issues occur, there are other devices successfully connected/working connected to the same rbs40 satellite unit, and I never have drops from non-IOS devices like my PC (wired to a rbs40) and printer (wifi to rbs40).  Would that be part of the backhaul issue you're referring to (I would think not, if other devices are working on the same satellite simultaneously)?  Or is it a backhaul issue whereby only certain devices may get dropped getting back to the router?  Thanks again..
    Retired_Member
    The backhaul problem should affect every device connected to the satellite wired or wireless. The drops are quick so a device like a printer would probably show no symptoms. If you try to ping Google with your laptop for a few minutes I bet you will notice some issues.
    • DarrenM's avatar
      DarrenM
      Hello VMK16
      You would have to get a wifi analyzer app Netgear has a free one on the Android store you may have to search for one on the apple store.
      DarrenM
      • TomMac's avatar
        TomMac
        Guru
        The app appears on Android store and Kindel store ( android based ) but not on Apple store
  • If an orbi router and satellite doesn't connect Is there any way to check the backhaul connectivity of the router to confirm if it is an issue with the router or satellite .@DarrenM
  • Hi DarrenM
    Thanks for the suggestion. Appreciated , I have one more question here the guest Network on orbi does that work on 2.4 GHz or both bands .
    • DarrenM's avatar
      DarrenM
      Hello VMk16
      Should work just like the main network and use both.
      DarrenM
