steve04KU
Sep 19, 2017Aspirant
iphone7 not connection to Orbi
Recently, my iPhone7 will not connect or stay connected to my Orbi wifi. It will show that it's connected under the phone's wifi menu w/ full bars, but the top of the home screen only shows "LTE", no...
DarrenM
Sep 21, 2017Sr. NETGEAR Moderator
Hello Steve04Ku
You may want to do a test activate the orbi guest network with no password and see if the IPhone will connect to that network. Or you can try in the advanced wireless settings uncheck the 20/40 coexistence.
DarrenM
