jrdawson
Feb 25, 2018Aspirant
Is the Orbi right for me?
I am thinking about buying the RBK44. But here is what I want to do... Currently I have a linkys wireless router and two linksys wifi repeters that create there own seperate wifi networks. But ea...
Feb 25, 2018Guru - Experienced User
To help troubleshoot some of these issues, try disabling Beamforming and MIMO and IPv6.
Set Manual channels 1, 6 or 11 on 2.4Ghz.
Set WPA2 and AES only.
I use these settings and have had zero issues. I presume there maybe some bad interaction behavior on the part of some Google devices here and there. Helps to give these features a try after disabling them.
