ChrizK's avatar
ChrizK
Tutor
Oct 04, 2021
Is there a Firewall blocking my other network?
Hi,
Firstly, I apologies if my network terminology is incorrect.
I switched broadband provider in the UK.  My old router DHCP provided 192.168.1 addresses, the new cannot be re-configured, and only allows 192.168.0 addresses.
I have attached my Orbi with DHCP enabled, providing 192.168.1 addresses.  This allows me to continue using all devices with static IP.  My new router still has DHCP providing 192.168.0 addresses, however, I have very few devices connected.
Should I refer to my Orbi as a Bridge, or perhaps a Gateway, in this configuration?
I can attach a device to Orbi, and I can reach my NAS on the other network (192.168.0).
Should I refer to these as 'subnets', or are they just 'seperate networks'?
The problem is, I cannot reach devices on the Orbi network (.1) from the new network (.0)
If I attempt a traceroute from the new (.0) network, it appears that it is 'correctly' attempting to route via the Orbi, but fails at that point (as expected, a PING completely fails).
This makes me think the Orbi is blocking the other network, but I cannot find any function (firewall?) that is doing this.
I would be very grateful for any help the community can provide.
(are there any logs showing firewall activity?  I coudn't spot anything under Administration>Logs.)
Many thanks
Trace Statistics: traceroute to 192.168.1.22, 30 hops max, 38 byte packets
1 *
2 192.168.1.1 (192.168.1.1) 2 ms
PING 192.168.1.22: 64 data bytes
--- 192.168.1.22 ping statistics ---
3 packets transmitted, 0 packets received, 100% packet loss round-trip min/avg/max = 0.000/0.000/0.000 ms
  • You can try #2 first and see if this helps, if not, try #3 on Orbi.
  • FURRYe38's avatar
    IF the ISP Modem has a built in router, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    Be sure all of your devices are connected to the Orbi system and not the ISP router.
    • ChrizK's avatar
      ChrizK
      Tutor
      Thank you for the quick reply, although I will have to think carefully how to proceed, given that you are saying what I am trying to do is not recommended :(
      Hardware Version   RBR50
      Firmware Version   V2.7.3.22
      I'm afraid I can't see who makes the Virgin Media Hub 4.  My googles just refer to it being their own.
      (but it is a router with Wifi capability)
      Doing what you suggest, I would have to move the Orbi from its current position, which has my Hive and Ring hubs wired directly, plus other devices.  This means I would have to find more power and space in the area in which the Hub4 is located, which is full of other devices (tv, satellite receiver, virgin tv, amplifier etc etc etc).  This is something I was trying to avoid, as the area is 'rammed'.
      I will have to read (and digest) what you have sent.
      Thanks for all your help, it is much appreciated
  • CrimpOn's avatar
    CrimpOn
    In this configuration, the Orbi is a router supporting a private network that is hidden from the ISP router network. The Orbi router's IP address on the ISP network will be 192.168.0.(something). The ISP network will have no idea where to find 192.168.1.(anything)  As FURRYe38 points out, this is a classic "Double NAT" situation. https://kb.netgear.com/30186/What-is-Double-NAT  Devices on the Orbi network can reach the NAS because they know "192.168.0 is not on the subnet with me, it must be out the gateway somewhere." The Orbi router knows "anything 192.168.0.x is on my WAN subnet."
    In itself, a Double NAT is not usually harmful, although it does make certain network activities very difficult (or even impossible, as described in the article).
    A "quick fix" is to attach all of your devices to the Orbi. They will all have 192.168.1.x addresses and will all be able to find each other.
    A better solution is to use one of the three method to eliminate the Double NAT.
    • ChrizK's avatar
      ChrizK
      Tutor
      Thank you for the additional information.  I will try and get my head around double NATting, but fear I will end up with power extention leads and boxes sitting on top of each other overheating a corner of the room :smileysad:
      • CrimpOn's avatar
        CrimpOn
        I made an invalid assumption (sorry).  Because the Orbi router must be connected to the ISP device with an ethernet cable, most customers locate the Orbi router right next to the ISP device.  With both in the same location, moving the NAS from one to the other is trivial.  With the Orbi located elsewhere, the situation is more complicated.
        If the Orbi is placed in Access Point (AP) mode, then the 192.168.1.x subnet will disappear.  All devices will get IP addresses from the ISP router in the 192.168.0.x subnet.  All will have internet access.  All will be able to communicate with each other. That requires no movement of equipment.
        Do all these devices have truly "Static IP addresses" (defined on the devices themselves), or are they assigned IP addresses in router tables?
        It might be worthwhile to identify how many devices on the 192.168.0.x network need to reach devices on the 192.168.1.x network.  I assumed (once again - assume) that it was only the NAS.  If that is the only one, then just move the NAS.  Or, does the NAS need to communicate with devices on both networks (i.e. a media server).
