blakejnd
Aug 05, 2018Aspirant
Issue with CBK40 and XFINITY / COMCAST
I just purchased a new CBK40. The installation went smoothly. I unplugged the XFinity modem I was renting and used the Netgear app which was a breeze. I should have known it was a little too e...
Aug 06, 2018Guru - Experienced User
After you go the system set up and running. Did you power OFF the CBR40 for 1 minute then back on?
How are you speed testing? Wireless or wired? Wired is preferred with a PC.
Try different browsers and different speed test sites and servers. Some servers maybe busier than others.
