dw33333
Jul 18, 2017Follower
Issue with my Orbi Satellite
So wondering if someone can help me on this. My orbi satellite has been acting up recently not broadcasting wifi. Before I get into it, I have power cycled the router, the satellite, the router and...
Ucchi
Jul 18, 2017Guide
Updated to Firmware 1.12.0.18
- Disabled the WiFi radios on Satellite. (WTF, seriously NetGear?)
Fix:
1. Manually uploaded previous Firmware 1.11.0.20 **Satellite Version, This is IMPORTANT** to Satelite manually via ip address (of your Satellite) in Web Address.
2. Manually uploaded Firmware 1.11.20 **Router Version, This is IMPORTANT** via web-portal.
-- This worked for me. Not sure if it will for you. Just sharing. Good luck.
- gbjacksonJul 25, 2017Apprentice
Had same problem - latest firmware update appeared to knock out satellite. Satellite showed in the web interface as a device, not as a satellite, and was showing as "disabled" when accessed via its IP address. Rolling back firmware worked.
Now, for the logical next question - can you disable automatic firmware upgrades?
- jad6osAug 09, 2017Aspirant
Why is this even still on their servers?! Netgear get it together, either fix the satelite firmware or remove the bad update so that we can roll back without having the broken update forced down our throats. Amateur hour....
- SayerAug 18, 2017Aspirant
Thanks Ucchi - that has stopped me returning the Orbi.
Netgear - Seriously concerned this made it through QA.- jad6osAug 23, 2017Aspirant
It has been a month, 6 downgrades to the firmware that works and 6 forced auto updates to the broken firware. This is so ridiculous and I regret every dollar spend on this subpar product.
