bbrener
Oct 12, 2018Aspirant
Issue with ORBI RBK20 Using RDP
My ORBI is set up and seems to be worling fine. Internet Speed 150MBPS and wifi speed almost the same in my house. However, I connect to my office using RDP protocol and this connection is very slow. When I type a key, it takes 2 seconds to show on the screen. Painting screens is slow as is opening email. There is a definite lag and I cannot find out why. My office PC is not slow when I am using it directly. My old TPlink router which which was an n router only worked perfectly. Any idea? I have tried most settings.
What FW is currently loaded?
What is the Mfr and model# of the ISP modem the NG router is connected too?Connection wireless or wired? Try wired to the base router?
- bbrenerAspirant
FW is the latest. V2.2.1.210. Everything is wired and I use a Motorola Surfboard DOCSIS 3.0 Modem SB6183. Had no issues with a TPLink router.
Was the FW updated via the auto update feature and continue or have you tried a factory reset and setup from scratch been performed. Might try this and this time don't enable QoS, Traffic Meter or Access Controls.
