RBK50_user1's avatar
RBK50_user1
Follower
Aug 15, 2019
Issues with Orbi AC3000 losing internet connectivity with ATT Uverse(NVG589)
I have ATT uverse and am trying to run my Orbi AC3000 in router mode behind it and I periodically, at least 2-3 a day lose connectivity to the internet.  The Orbi management page shows no errors in internet connectivity and all devices both wired and wireless have connectivity to the Orbi.  However, I can't get any connectivity to the internet, as an example if I try to ping anything it times out.  I have found in this situation if I go to the Orbi managment page and just run a Test connectivity from the internet tab once it gets about halfway through my internet connectivity comes back up.  Otherwise I have to wait several minutes for this to resolve itself.  I have updated to the latest Firmware on the Orbi.  And yes I know I can put it in AP Mode, but then I lose some of the router functions I bought the Orbi for, specifcally Circle.
Lastly as far as I can tell the NVG589 is setup correctly.  When I first set the Orbi up as a router I had issues with double NAT'ing, but was able to solve that by changing the settings on the Uverse box.  I had a previous Linksys router so I just needed to update the Uverse box with the Orbi MAC address, directions here http://www.dslreports.com/faq/17734.  Everything after that cleared up, except for this loss of connectivty, anyone else experience this and solve it?
  • This must be related to the ISP lease time issue that was introduced in recent Orbi updates and is still there in the latest 2.3.5.30.
    A tested workaround that I currently have and has solved this issue for me to to reduce the lease renewal time in Orbi as follows:
    * From browser go to the router's debug page (http://192.168.1.1/debug.htm). Use your router's IP address or http://orbilogin.com/debug.htm
    * Enter admin as user name and your router’s management password
    * Tick "Enable Telnet" option
    * Use Telnet from a computer attached to Orbi to connect to your Router telnet 192.168.1.1 and enter admin and the same password as above
    * Enter the following commands:
    * root@RBR50:/# config get wan_lease    — Should give you --> 86400
    * root@RBR50:/# config set wan_lease=720
    * root@RBR50:/# config commit
  • FURRYe38's avatar
    Modem Combo Units:
    This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    I would try Option #2...
