crawdawg83
Sep 11, 2020Aspirant
Issues with RBK20W
I evacuated for Hurricane Laura and before I left I had powered down and unplugged my modem and router. The modem is a Nighthawk MR1100 and going to the Orbi RBK20W. Upon returning home and plugging everything in it worked at first. However, every morning I've had to reset them due to lost connection. In addition I've had several times a day that signal from the WiFi has dropped. The signal appears good on the Nighthawk which has an ATT sim card for service. After a few days of trying to factory reset both modem and router only to still have the issues, I turned on my PC this morning while the wifi signal was lost. The pc has an Ethernet from the Orbi and it still had connection, but all the wifi devices did not! I'm now lost as to why I have ethernet but wifi is spotty? The satellite is not too far away from the base unit or router. My house is 2400 sq ft. Before all of this I had great signal throughout the house. I don't understand why after being gone a few days and everything was unplugged, it's now on the fritz.
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
https://kb.netgear.com/19668/Link-Rate-and-Transfer-SpeedTry enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).One User Experience/Configuration:
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026- crawdawg83Aspirant
I tried all the above steps as recommended without any improvements. I tried removing my Orbi completely and only used my old Netgear router and after a few hours it too lost connection. My modem is the Nighthawk MR1100 with an ATT sim card. I put a new sim card in and had it synced with the tower closest to me. This didn't improve anything. So, if I have the same issues between 2 routers to the same modem at seperate times, but the modem never gives a message that it has lost connection to the internet, then what shoud I diagnose next? I'm running out of things to do here.
- MstrbigMaster
crawdawg83 wrote:I tried all the above steps as recommended without any improvements. I tried removing my Orbi completely and only used my old Netgear router and after a few hours it too lost connection. My modem is the Nighthawk MR1100 with an ATT sim card. I put a new sim card in and had it synced with the tower closest to me. This didn't improve anything. So, if I have the same issues between 2 routers to the same modem at seperate times, but the modem never gives a message that it has lost connection to the internet, then what shoud I diagnose next? I'm running out of things to do here.
Unplugging devices for long periods of time can cause issues sometimes.
If you removed the Orbi completely and still had an issue, it is definitely not the Orbi.
More than likely you are losing connection to the ATT tower, or There is something wrong with the MR1100, as there are many complaints about it dropping the network. Try searching the net with the symptoms pointing to the MR1100. I found several topics on how to possibly fix it. This was the most common:
Get a new sim card. Ggo into settings and select LTE ALL under network settings
