tallack's avatar
tallack
Latest updates nerfed wireless range!!!
No idea why, but the latest update nerfed wireless range!  My 2.4GHz devices (doorbell and security cameras) now have horrible, or no, signal.
I am in NZ (but they only have Australia country domain), so I know the EIRP is 4W for both on the 2.4GHz band.  I can't imagine any reason for Netgear to have wound it down.
Anyone out there in ANZ (or any other domain) find their coverage is horrible after update?
  • Faced same problems since firmware upgrade to .60. Had to downgrade to .48 to “fix”. Latest version should be pulled and fixed.
    • tallack's avatar
      tallack
      I went back to 2.2.1.212 "just to be sure".
      Bloody rude of them to nerf the power.  :(
      • ekhalil's avatar
        ekhalil
        Master
        You can check the transmission power (and change it) in Orbi using the following telnet commands:
        root@RBR50:/# iwlist ath0 txpower
        ath0      8 available transmit-powers :
                  0 dBm         (1 mW)
                  6 dBm         (3 mW)
                  8 dBm         (6 mW)
                  10 dBm        (10 mW)
                  12 dBm        (15 mW)
                  14 dBm        (25 mW)
                  16 dBm        (39 mW)
                  18 dBm        (63 mW)
                  Current Tx-Power:18 dBm       (63 mW)
        Where the interfaces are as follows (in RBR50):
        ath0 (Fronthaul 2.4GHz)
        ath1 (Fronthaul 5GHz)
        ath02 (Guest 2.4GHz)
        ath11 (Guest 5 GHz)
        ath01 (Backhaul 2.4GHz)
        ath2 (Backhaul 5GHz)
