DG1980's avatar
DG1980
Tutor
Nov 11, 2020
Login to Orbi router displays not secure, using HTTP instead of HTTPS
After I log in to my router, connection status on the browser shows "Not secure". I click the exclamation icon and see "Your connection to this site isn't secure". I'm using the latest firmware, V2.7.1.60 (see attachment).
I also noticed the connection is using HTTP instead of HTTPS, which is probably the culprit. I don't recall when, but I'm sure at some point the connection was secure. This may have something to do with an invalid or expired certificate.
Is anyone else having this problem?
    • DG1980's avatar
      DG1980
      Tutor
      I get a security warning then choose to proceed anyway. It lets me in but the https is crossed out (see screenshot). Also, the firmware version is 2.7.1.60, which is newer than the one you suggested and "Always Use HTTPS to Access Router" is enabled (see screenshot).
      • FURRYe38's avatar
        Actually v2.7 is a different fork from v2.6 and v2.7 has different features from V2.6. v2.7 is meant for USA region users only.
        Always Use HTTPS to Access Router is used for remote access from remote locations from the WAN side. This doesn't enable HTTPS on the LAN side of the router on it's web page.
  • FURRYe38's avatar
    I would contact NG support about the local management to see if this is the case with v2.7.
    Blanca_O olympos1625
    The remote mangement option is for the WAN side only though when Turn Remote Managment ON is enabled:
    • schumaku's avatar
      schumaku
       DG1980 Even if there is https support for the LAN - there is no f***n way that https://[LAN-IP] (or even a hostname put in by some tricks) will show anything different but a security warning, and on continuing a red "Not secure" on top in the current modern web browsers. nothing groundbreakingly wrong with it...
