mkbrand
May 24, 2019Aspirant
Logitech Squeezebox Won't stay connected to rbk50
I have 3 logitech squeeze box classics(running on 2.4 ghz) using the Logitech Media server to send music from my computer to my stereos It does not work with my RBK50 (I have one satelite). It continually drops connection, stops music, reboots the squeezebox unit, and occasionally sends screeching sounds through the speakers. I don't have any other problems with the Orbie; it covers my house with stong consistent signal. But my music system is non-functional. has anyone out there had this problem? Or, more importantly, solved this problem?
Thanks for your help.
Is the Orbi system operating in Router or AP mode?What is the size of your home? Sq Ft?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s). - FURRYe38Guru - Experienced User
Any progress on this?
mkbrand wrote:I have 3 logitech squeeze box classics(running on 2.4 ghz) using the Logitech Media server to send music from my computer to my stereos It does not work with my RBK50 (I have one satelite). It continually drops connection, stops music, reboots the squeezebox unit, and occasionally sends screeching sounds through the speakers. I don't have any other problems with the Orbie; it covers my house with stong consistent signal. But my music system is non-functional. has anyone out there had this problem? Or, more importantly, solved this problem?
- mkbrandAspirant
Unfortunately, I have not made any progress on this issue. I have not had time try the suggestions that were given. I will keep you posted if any of the items suggested work. Thanks for your help.
Ok, please let us know. Also please give feedback to the questions presented when you get time.
