JQNX
Mar 06, 2017Tutor
Losing Wireless Connectivity
Hello guys, So basically the first few days the Orbi system worked just fine. But now I'm losing the connection every 1/2 hrs. I'm connected via Lan-Cable to my PS4. I don't know if it has something...
JQNX
Mar 11, 2017Tutor
Nothing changed. Tried everything. Can I turn off auto-firmware-update. I never had that issue, if it lasts for more than one week I'll return it.
DarrenM
Mar 14, 2017Sr. NETGEAR Moderator
Hello JQNX
Did you try to manually reload the older firmware that you had no issues with?
Wizard488
Did you try adjusting the position on orbi in your home or adjusting the wireless channel in the wireless settings?
DarrenM
