JQNX
Mar 06, 2017Tutor
Losing Wireless Connectivity
Hello guys, So basically the first few days the Orbi system worked just fine. But now I'm losing the connection every 1/2 hrs. I'm connected via Lan-Cable to my PS4. I don't know if it has something...
DarrenM
Mar 16, 2017Sr. NETGEAR Moderator
The engineers are working on the disconnect issues and the latest firmware did not have these fixes in it.
DarrenM
Thorborg
Mar 25, 2017Guide
I have the same issues, where the connection drop 10 times af day.
When is the new firmware expected?
- DarrenMMar 27, 2017Sr. NETGEAR Moderator
Hello Thorborg
Have you made sure beamforming and Mu MIMO are disabled? also you could try to lower the power level of the 2.4ghz in the advanced wireless settings some have said this have helped.
DarrenM
