JQNX
Mar 06, 2017Tutor
Losing Wireless Connectivity
Hello guys, So basically the first few days the Orbi system worked just fine. But now I'm losing the connection every 1/2 hrs. I'm connected via Lan-Cable to my PS4. I don't know if it has something...
JQNX
Jun 02, 2017Tutor
Well, after testing it a few more weeks I'm so done with the Orbi system. Getting disconnects hourly.
Router is on AP mode. PS4 connected to the satellite via Lan-Cable. I really do not know what to change anymore. Not even the static ip works. Called the support and they told me to wait and see what happens. Well... This is getting ridiculous.
- ThorborgJun 05, 2017Guide
The latest update solved it for me, I'm 100 % happy now :-)
Cheers
Martin
- JQNXJul 27, 2017Tutor
It worked for me a few days but that time I only used the Orbi as Router without the satellite. Today the disconnects are back and I don't know what to do, probably getting rid of it anyways.
