CarolGZ
Mar 29, 2020Aspirant
Magenta! Add-on Outdoor Satellite(RBS50Y) won't sync with RBR850 - Orbi Tri-band Mesh WiFi 6 Router
Greetings! I've followed all directions and troubleshooting tips but I can't get my new Orbi add-on satellite (RBS50Y) to sync with my Orbi RBR850 mesh wifi router. I had no trouble setting up the router and the satellite that came with it. But when I try to sync the RBS50Y I get the Magenta light indicating failure to connect. I've tried everything suggested by the documentation.
I need to set this up to teach a class starting Tuesday. Would be grateful for any help! Carol
I would first attempt to sync the RBS50Y in the same room with the Orbi router. It is a lot easier to see what is happening when all the devices are in the same location. The User Manual on page 12 indicates that "pulsing magenta" means the sync button is disabled, and "solid magenta" indicates it did not connect.
http://www.downloads.netgear.com/files/GDC/RBS50Y/RBS50Y_UM_EN.pdf
- CarolGZAspirant
Thank you, I've done all these things! There seems to be a deeper issue not covered by the documentation. But thanks for the quick response! :)
Like other Orbi's, the satellite has a tiny "Reset" hole on the back. Since the satellite appears to be "DOA", it cannot hurt to try resetting it to Factory.
Unfortunately any RBS50 series satellite is not yet wirelessly complatibe with the Orbi AX system. NG has mentioned that at some point they will be makiing them compatible. No time frame or when this will happen.
For any Orbi AX support or information, please post in the Orbi AX forum here:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
