jlewis11's avatar
jlewis11
Follower
Nov 03, 2020
Max speeds on orbi rbr50
I recently upgraded to 1GB internet access.  I have tested the download speed plugging a Lan cable into the back of the orbi router to eliminate any WIFI issues and I get between 200MBPS and 400MBPS.  Is there a max limit the Orbi can handle or should I be able to get close to the 1GB speeds?
