Nibir
Jul 06, 2020Aspirant
Most Stable Orbi Configuration
Orbi Model: RBK53 V2 (with additional satellite i.e 3 Satellites and 1 Router) Firmware Version: 2.5.1.16 (Updated Manually) I have replaced my NightHawk system with Orbi Mesh System couple of mont...
Jul 06, 2020Guru - Experienced User
Thanks for posting.
I use similar configuration.
I don't see orbi app with wrong map or doesn't take long for for it to detect my devices. It may depend on your device and OS your device is using as well.
If you think you see problems with the app, please post about them in the orbi app forum:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
Good Luck.
