Nibir
Jul 06, 2020Aspirant
Most Stable Orbi Configuration
Orbi Model: RBK53 V2 (with additional satellite i.e 3 Satellites and 1 Router) Firmware Version: 2.5.1.16 (Updated Manually) I have replaced my NightHawk system with Orbi Mesh System couple of mont...
Jul 22, 2020Guru - Experienced User
Need to use a PC or laptop and connect to the RBRs web page using a web browser to access these settings.
kwtb2488 wrote:Sorry to sound like an idiot but where do i find most of these settings to change to what you suggested? I found the Guest Network and Remote Management under Settings in the Orbi mobile app but wasnt sure about the others. Appreciate it, thanks!
kwtb2488
Jul 22, 2020Aspirant
Thanks. I made the changes, Hoping it helps the Orbi from dropping once a day.
