Michelli69's avatar
Michelli69
My RBK14 router did not come with a password
My router did not come with a password, therefore use is unprotected. How do I create one?
  • FURRYe38's avatar
    Use a PC or laptop wire connected to the RBR and log into the RBRs web page use a web browser and setup a wifi SSID PW.
    Please review the user manual as well for addtional help and information.
  • CrimpOn's avatar
    CrimpOn
    Sometimes it helps to specify which "password" is missing.  When the Orbi comes "out of the box", it is supposed to have two "passwords."
    1. The WiFi password is printed on the product label, along with the default WiFi name (SSID).
    2. The administrative login to the Orbi web interface (http://orbilogin.net) is user "admin" and password "password".  Not very 'secure', but not 'missing'.
    It would help to know how this Orbi was set up (using a web browser or using the Orbi "app")
    • Michelli69's avatar
      Michelli69
      Thanks for your reply. There was no Wifi password printed on the product label below the SSID, that space is blank.
      Orbi was set up manually using the app. (barcode scanning wasn't recognized). Despite correct step-by-step manual setup, it still returned a "Router Not Found" message. Issues all around.
      • FURRYe38's avatar
        See if you can connect using a wired connected PC to the router.
