Betocamara's avatar
Betocamara
NAS and RBK53 best Connection to Router or Satellite
I have a RBK53, is it possible to configure one satellite wired and the second wireless expanding the first wired satellite signal instead of using the router?
Do I have a performance loss in this configuration?
Also for a NAS server the performance is the same if I connect it to the wired Satellite instead to the router?
1 Reply
  • FURRYe38's avatar
    Performances should be the same if wired backhaul.
    Might see if Daisy Chain feature works.
    The more you put something in the middle of a wired connection, there can be some degradation. Best to keep things simple as possible. If you need performances with NAS then you might consider a external Gb switch after the router and connect the NAS and any wired PCs and devices to this switch. Be sure its a NON-Managed switch. Don't use a managed switch.
