Sennevds
May 29, 2019Aspirant
Nat loopback
Hi,
I've found a thread about nat loopback but no answer. It looks like nat loopback is not working. I've configured port forwarding which is working perfect when using data on phone of from another network.
When i'm trying to use the same dns name and port from within my home network I can't connect to my webapp.
Is this a known issue(or feature) or do I have to change some settings?
Its possiblet that loop back isn't supported on Orbi.
Sennevds wrote:It looks like nat loopback is not working. I've configured port forwarding which is working perfect when using data on phone of from another network.
Netgear has a web site (dated August, 2018) showing which router models support NAT loopback:
https://kb.netgear.com/000049578/NETGEAR-Router-support-for-NAT-Loopback
None of the Orbi models appear on the list. Since Orbi is based on OpenWRT and the Nighthawk line is not, my guess is that Orbi does not support NAT loopback.
