alterndog's avatar
alterndog
Follower
Feb 06, 2020
Netflix Orbi issues
I have an Orbi RBR50. We switched to a Fiber Optics provider and since then netflix continues to buffer and have lower quality. I talked to the service provider and they don't see any issue on their end so I gather it's something with the Orbi. FM is V2.3.5.30. Any ideas on how to potentially fix the issue?
  • FURRYe38's avatar
    What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here by chance? Is the Orbi system operating in Router or AP mode?
    Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
    Might update FW to v2.5.1.8 later on.
  • I have the samme problem after switching til fiber my Netflixapp on my LG B6 keeps loosing connection and buffers. When I use my Chromecast 4K there is no problems with the Netflix streame. All other apps on the tv are woorking fine.
    I am on V. 2.5.1.8 on my RBR50 with 2 sattelits. Sadly I have not found a solution yet....
    • FURRYe38's avatar
      Try using the netflix app with the RBS's turned off.
      What devices do you have the netflix app installed on?
      Has a factory reset and setup from scratch been performed since last update?
