quaningeneva's avatar
quaningeneva
Apprentice
Feb 27, 2019
Netgear Armor cannot activate in Firmware 2.3.0.32
Netgear Armor cannot activate in Firmware 2.3.0.32.  Already tried multiple resets and factory restore.
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi quaningeneva
    What is the iOS or Android app version?
    What is the model of the Smart phone used?
    Have you tried using a different smart phone?
    Blanca
    Community Team
    • quaningeneva's avatar
      quaningeneva
      Apprentice
      I am using iOS.  Tried both iPad and iPhone. Using the latest app. On the iPad, 2.2.13.22.
  • ErnestTheGreat's avatar
    ErnestTheGreat
    quaningeneva Have you used Netgear Armor on R7000P or have you previously activated Netgear Armor?
    If you have not previously used Netgear Armor then issue maybe related to your SSO or device not being able to register to Netgear X-Cloud to make the activation process with Netgear Armor on Bitdefender side possible. Netgear will need to get the Xcloud logs and your contact info including SSO. Could you please DM Blanca_O  with your contact info?
