daeaiaea's avatar
daeaiaea
Netgear CM1150v and ORBI RBR40 system issues
Please bear with me here as I am a networking rookie.  I had ATT system for years and added Orbi RBR40 in last two years.  constant issues with reliability of ATT service so a move to a new house naturally meant a switch in ISP.  I now have Xfinity Blast Pro plus voice.  I invested in the CM1150v to avoid the monthly rental fees from Comcast to pair with my Orbi system (RBR40).  After numerous power cycles of both modem and router i seemed like everything was fine (laptop wired to modem worked fine) so it seemed I was ready to be wireless after I did a few more powercycles and got the modem plugged into Orbi.  Orbi tests fine as well (delivering 180 down and 7 up), I was happy until of course i realized the spotiness of the setup.  Samsung Smart HUB on TV doesnt connect at all, while the Apple TV (netflix) works fine.  Amazon Prime on that same apple tv doesnt connect either.  The app store on IOS devices wont download new or updatesto apps.  Xfinity doesnt want to troubleshoot because its not their equipment and discussion with Netgear are Tier 1 issues and as soon as they prove modem gets signal they are done because ORBI is 'different'.  My honeywell thermostats are all online with same network and whether laptop or mobile deevice I am clearly getting some internet, some sites work while others dont.  Please help this rook out!!
  • Reason for testing a PC directly to the modem is to rule out any problems at the modem first. IF something appears there that seems problematic, then the modem would need to be looking at first. If the modem and PC work fine with these sites, then the Orbi would need to be looked into next.
    https://community.netgear.com/t5/Orbi/bd-p/Orbi
  • FURRYe38's avatar
    With a wired PC directly connected to the CM modem, do you get internet and access various sites and speeds are ok? If so, then I would post about getting some help in the Orbi forum. This maybe a Orbi issue if the CM modem is working to spec and ISP says signal is good up to the modem.
  • I have everything hooked up, have WiFi...... but cannot get on all the web-sites I need. I work from home. MUST be able to get on these sites!
    • FURRYe38's avatar
      Need to verify first with a wired PC directly connected to the CM modem, do you get internet and access various required sites and speeds are ok wiht the modem only...
      • pmassey's avatar
        pmassey
        I did that. I can get on most sites, but a select view, ( that I need for my job) won’t let me get on.
    • daeaiaea's avatar
      daeaiaea
      p -
      have you attempted directly wiring to modem/gateway?  I have done this myself but i didnt test these problem sites.  I suppose my ORBI setup could be the culprit and will test when i am home...
      • FURRYe38's avatar
