loomis1975's avatar
loomis1975
Luminary
Sep 23, 2016
Netgear Contacted me to Write A Review
Netgear contacted me to write a review, which is fine, I just copied my review for Best Buy, but then they copied it into the clipboard and wanted me to post it at Amazon.  Link went right to the product page at Amazon, but only problem is, Amazon won't let me post a review for something I didn't get through their website (Got the Orbi through Best Buy).  So I couldn't do it, but I would be happy to.
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Loomis1975
    That should be fine if you posted a review where you purchased the device.
    DarrenM
    • UnCapitano's avatar
      UnCapitano
      Apprentice
      I can post it for you.  I actually posted a review on Amazon myself, even though I'd received mine from Best Buy.  Great job, Netgear, but now I need that extra satellite.
      • DarrenM's avatar
        DarrenM
        Hello Uncapitano
        Thanks for the review and the satelites should be coming soon keep a eye on your vendors website.
        DarrenM
