mongotz
Jan 28, 2020Aspirant
NETGEAR Orbi AC3000 Tri-band Wi-Fi System maximum satelittes
I have the system set up with the main router, the two satellites that came with the package and an RBS50Y outdoor router to make up 3 satellites. My ring doorbell is just not recieving enough signal. Should I add an RBW30 Orbi 802.11AC Wireless Range Extender Adapter or another item? How many satellites does the system support?
Thank-you for the help.
Lets check a few things first before adding any more satellites. What you have should be already enough.
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try disabling the following and see:
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).You may have a faulty ring door bell device as well. Try a different door bell unit.
mongotz wrote:I have the system set up with the main router, the two satellites that came with the package and an RBS50Y outdoor router to make up 3 satellites. My ring doorbell is just not recieving enough signal. Should I add an RBW30 Orbi 802.11AC Wireless Range Extender Adapter or another item? How many satellites does the system support?
- mongotzAspirant
FIRMWARE 2.3.5.22
Arris Optimum Modem TM1602A
Home 3500 sq ft
All units stacked on 3 floors above each other, outdoor one in garage.
Router settings cannot be discerned thru Optimum
I have app on phone but don't see how to change channels but have done before with other routers
No Armor or any of that type.
Bell connection for viewing is on and off when I try to access and alert works fine when someone comes to the door. Alerts thru all Alexa devices. Connected to doorbell power, battery constant charge (Ring 2)
Bell shows signal strength of RSSI-49
That size of home having two is enough. I'd maybe turn OFF one and test.
To change channels on the Orbi system you have to log into the RBRs web page at orbilogin.com with a PC or laptop with a web browser.Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).Also you might update FW on the RBS then RBR at some point. v2.5.1.8 is currently released and most stable.
