HirsuteKnight's avatar
Aug 02, 2017
Netgear orbi and Bt smart hub
I've tried unsuccessfully to use the orbi with my bt smart hub. I thought it was plug n play but it's not working. Do I need to do something with either the orbi or the bt smarthub router. Apologies - a real know nothing on the topic.
  • Anonymous's avatar
    Anonymous
    Aug 03, 2017
    The best way to set this up is to disable wifi on the BT SmartHub and then use the Orbi in AP (Access Point) mode. The main Orbi unit needs to have a network cable connecting it to the SmartHub.
    Alternatively you can replace the SmartHub with a VDSL modem (I use a Vigor 130) and then use the Orbi in Router mode.
    Anonymous
