Leniad
Oct 19, 2023Aspirant
Netgear Orbi Voice RBS40V I can't Set up with a router that is not an Orbi
My Netgear Orbi Voice RBS40V cannot be configured as an Extender following the guide to configure my Orbi voice as an extender when I don't have an Orbi router: https://www.downloads.netgear.com/f...
- Oct 20, 2023
First many thanks for your assistance and good news! I found the solution of how you set up in extender mode the RBS40V (without -200 model or Ver. 1), the solution is in this link:
"How do I setup my Orbi Voice RBS40V in Extender Mode?"
https://kb.netgear.com/000061427/How-do-I-setup-my-Orbi-Voice-RBS40V-in-Extender-Mode
the trick is the Sync button and the SSID show the EXTENDER_EXT, so now my RBS40V is working with another router.
Thanks
CrimpOn
Oct 19, 2023Guru - Experienced User
Might help to check the specific model number on the product label (bottom of the case).
Version 1 is compatible only with Orbi routers:
https://www.netgear.com/images/datasheet/orbi/RBS40V.pdf
Version 2 has two separate 'modes', Orbi satellite and WiFi Extender:
https://www.netgear.com/images/datasheet/orbi/RBS40V-200.pdf
