Leniad
Oct 19, 2023Aspirant
Netgear Orbi Voice RBS40V I can't Set up with a router that is not an Orbi
My Netgear Orbi Voice RBS40V cannot be configured as an Extender following the guide to configure my Orbi voice as an extender when I don't have an Orbi router: https://www.downloads.netgear.com/f...
- Oct 20, 2023
First many thanks for your assistance and good news! I found the solution of how you set up in extender mode the RBS40V (without -200 model or Ver. 1), the solution is in this link:
"How do I setup my Orbi Voice RBS40V in Extender Mode?"
https://kb.netgear.com/000061427/How-do-I-setup-my-Orbi-Voice-RBS40V-in-Extender-Mode
the trick is the Sync button and the SSID show the EXTENDER_EXT, so now my RBS40V is working with another router.
Thanks
CrimpOn
Oct 20, 2023Guru - Experienced User
You did this, and it worked?
Would have been a lot easier if this had been mentioned in the Product Data Sheet, Installation Guide, or the User Manual.
Leniad
Oct 21, 2023Aspirant
hi,
If it works wonderfully, I was already disappointed by the simple fact of wasting a great product, but when I did one last search on Google,voilĂ ! the answer!!, and exactly what you say, why the userÂŽs manual does not contemplate that and you end up finding it in a KB, well today something new to learn, let's share wisdom đ
