Reyesani
Jan 04, 2019Follower
network connections
System is Actually the RBK20W-100NAS
After a frustating installation and lengthy(more than 3 hours & two stump agents) troubleshooting latenight early morning phone conversation with my internet provider I am still unable to connect the Orbi system to all of my devices. My Sony Television and our android cell phones. I've have seached multiple forums for a solution without success. The connection on my phone states that the "Internet may not be available", the App tells me that the WiFI router has not been configured and wants me to perform a new set up yet my Ios, tablets, phones and laptop are all connected. I have also changed some settings on my phone.
1 Reply
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
What WPA security modes are you using? Try WPA2 and AES only.Try disabling the following and see:
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Disney Circle: https://community.netgear.com/t5/Orbi/WARNING-Firmware-2-2-1-210-is-junk/m-p/1667485/highlight/true#M45926If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually. Advanced Tab/Advanced Settings/Wireless Settings
