Chuck1806
Jul 27, 2026Aspirant
Network map
How do you remove an old satellite RBS50 that was damaged from the network map? I open the satellite profile and can see the Details. It indicates the Connection Type as "Offline" but no option to ...
- Jul 27, 2026
Log into the RBRs web page using it's IP address using a web browser. On the Connected devices page there, if the RBS is OFF or not connected and had been there should be a Disconnect button for the RBS entry here that you can select to remove it from the system.
Chuck1806
Jul 29, 2026Aspirant
I really appreciated you help
Thank you😎
Jul 30, 2026Guru - Experienced User
Enjoy. 📡
