Feb 25, 2019Guru - Experienced User
New - NetGear Orbi Firmware Version 2.3.0.32 now available...
FW 2.3.0.32 is now available on our support site :
https://www.netgear.com/support/product/RBK50.aspx#download
RBR/RBS 50 Series Only.
To manually update the firmware, there is a need to ...
frewster
Feb 28, 2019Guide
Everything is still working great. I manually updated a few days ago without having to reset anything. This is the best the Orbis have ever worked for us.
- Chuck_MMar 01, 2019Mentor
There has been a lot of chat about resetting before updating; I didnt do any of that before I did the manual firmware upgrades and it works just fine.
- Damit1Mar 01, 2019ApprenticeDid reset my Orbi while doing these tests.
Sadly my speeds issue just will not resolve.
If in previous FW had a peaks to 900M.
Now not more than 530-560.
It is what it is.
Did a reset to both units to prevent every possible issue.- FURRYe38Mar 01, 2019Guru - Experienced User
https://community.netgear.com/t5/Orbi/Rbk50-speed-issues/m-p/1714604/highlight/true#M54147
It is what it is.
