Feb 25, 2019Guru - Experienced User
New - NetGear Orbi Firmware Version 2.3.0.32 now available...
FW 2.3.0.32 is now available on our support site :
https://www.netgear.com/support/product/RBK50.aspx#download
RBR/RBS 50 Series Only.
To manually update the firmware, there is a need to ...
Chuck_M
Mar 01, 2019Mentor
There has been a lot of chat about resetting before updating; I didnt do any of that before I did the manual firmware upgrades and it works just fine.
Damit1
Mar 01, 2019Apprentice
Did reset my Orbi while doing these tests.
Sadly my speeds issue just will not resolve.
If in previous FW had a peaks to 900M.
Now not more than 530-560.
It is what it is.
Did a reset to both units to prevent every possible issue.
It is what it is.
- FURRYe38Mar 01, 2019Guru - Experienced User
https://community.netgear.com/t5/Orbi/Rbk50-speed-issues/m-p/1714604/highlight/true#M54147
It is what it is.
Did a reset to both units to prevent every possible issue.- raven_auMar 01, 2019Virtuoso
Just an fyi.
The Netgear web site still lists the v2.2.1.210 firmware as latest for the RBK50.
That really should be offering the same firmware as the RBK53, RBR50, RBS40, etc.
- TC_in_MontanaMar 01, 2019VirtuosoNot necessarily true. Depending on how you dig down the newer versions are also listed. If you go straight to downloads, the old version is listed as most current.
If you go to the RBR50 or RBK53 or other 59 series devices then check downloads, the newer versions of the firmware are listed and available for download.
