Feb 25, 2019Guru - Experienced User
New - NetGear Orbi Firmware Version 2.3.0.32 now available...
FW 2.3.0.32 is now available on our support site :
https://www.netgear.com/support/product/RBK50.aspx#download
RBR/RBS 50 Series Only.
To manually update the firmware, there is a need to ...
porlockweir
Mar 04, 2019Guide
Has anyone else had issues with Armour enabled? I upgraded the the firmware yesterday but started getting problems with browsers on multiple devices reporting insecure connections and invalid certificates last night along with Echos being unable to connect. Disabling Armour appears to have fixed it so far.
Mar 04, 2019Guru - Experienced User
Have you power cycled the Orbi after the FW update?
Might need to factory reset the router and setup from scratch.
Others haven't reported problems with Armour as of yet. A few activation issues mostly.
You can post here regarding Armour Questions and help:
- larryindublinMar 04, 2019Luminary
I'm also having no Armor issues (except the occasional false vuln report) and have 6 Alex devices connected as well as a mess of other home automation devices.
- FURRYe38Mar 04, 2019Guru - Experienced User
Good to hear. Thank for posting your experiences with Armor. Please post here as well:
Thank you.
