FURRYe38's avatar
New - RBR50 / RBS50 Firmware Version 2.7.4.24 Released
New Features and Enhancements:
  • Admin password brute force attack prevention
  • Admin password strength enforcement
  • EU data analytics opt-out
Bug Fixes:
  •  The backup config file is an incorrect file after some configuration changes
Security Fixes:
  • Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security/
Download Link:
https://www.netgear.com/support/product/RBK50#download
Firmware Update Instructions:
To update your product’s firmware, follow the instructions in your product’s user manual.
To find your user manual, visit https://www.netgear.com/support/
Then enter your model number in the search box, and click the Documentation button on the product page.
NOTE: Orbi app or the routers web page may not report seeing new FW updates. NG may not push this to there auto update services immediately and may activate the newer FW update being seen on there auto update services at a later time. User will have the choice to manually update if you want too.
If you manually update, be sure to update the RBS first, then RBR lastly.
https://kb.netgear.com/000037217/How-do-I-check-and-manually-upgrade-the-firmware-on-my-Orbi-satelli...
https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-router-using-orbilogin-co...
NOTE:  Update the RBS first, then the RBR lastly. After the FW files are loaded and the RBS and RBR are ready, power OFF the RBS and RBR for 2 minutes then back ON.
Unplug the power adapters from the power wall outlet.
A factory reset maybe needed if problems are encountered:
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
This article applies to:
Let us know how it works for you in this thread please.
  • The RBR50 V2.7.4.24 apparently causes some SMTP delay issues.
    I have an HP Laserjet MF that allows me to scan to email. It basically pushes the scan to an SMTP server. After upgrading to the 2.7.4.24 firmware, I noticed it that took 15-30 min (or more) to get a scan delivered to email. Issue happened with outlook, O365 and gmail (both with 2 step verification enabled/disabled). The HP Laserjet display showed that it keeps connecting to the SMTP server...
    Problem disappeared when downgrading to V2.7.3.22.
    Does somebody know what setting could be causing this issue? Or is this is a known V2.7.4.24 software/firmware issue?
    Thanks
    • FURRYe38's avatar
      Did you factory reset and setup from scratch after applying v.24 FW to the system?
      • DimitriM's avatar
        DimitriM
        The ISP coax modem is a Compal CH7465LG HGW 3.0 (via Telenet / Liberty Global in Belgium).
        No, I didn't perform a factory reset because I preferred not to through the hassle of reconnecting all devices etc.
        Thanks
    • Jeffgear's avatar
      Jeffgear
      Virtuoso
      Hi Dimitri
      I’m not sure this is the same workflow but I have an Epson inkjet on wifi only and can scan a document and select send to email from the printer front panel. There is no delay in the Epson scan applet popping up on my MacBook that is also on wifi and accepting the scanned document to be attached to an email that then sends without delay. I receive via my gmail email fine within a minute. I’m an on the 2.7.4.24 release.
      • Jeffgear's avatar
        Jeffgear
        Virtuoso
        I can also from my phone (off and on the same wifi as the printer) send a photo via my Epson print service email or send an email with or without document attachments and it prints within a minute, albeit slowly. Interestingly though if I forward an email with HTML content like the Netgear community email update then I get an error in an email from Epson. CAUSE:
        Your email had no printable content in the email body or any attachments.
        I even get this if I add enter some text above the email to be forwarded. The Epson server must not like rich content and probably does this as a basic malware screening control.
  • I wonder when we will see the next version of the RBK50 firmware.... Netgear isn't very progressive when it comes to new firmware releases in my opinion.
    And when they release something new, it's just more of the same without any fundamental changes.
    I'm thinking about switching to Voxel's firmware, but lately it's quiet on that side to....
    • FURRYe38's avatar
      FYI, since the Orbi AC series has been developed over the years, it's become more and more mature. Thus NG may not release new FW updates as often as before. And it's only been 8 months since this version was released. Also may depend on any bugs and security issues that maybe out there.
  • Well, it looks like my Orbi auto-updated my firmware sometime in the last week to the 2.7.3.X firmware, which seems to have "restored" the issue of dropping internet connections (likely DNS issue) forcing me to power-restart the Orbi multiple times per day to keep restoring the internet. I then upgraded to this latest firmware hoping it would help, but no luck.
    This issue first showed up with the 2.7.2.104 firmware about 2 years ago (https://community.netgear.com/t5/Orbi-Wi-Fi-5-AC-and-Orbi-with/RBR50-intermittent-DNS-lookup-issues/m-p/2085640#M119278) and was ultimately resolved by factory resets and rolling back several firmware versions.
    Now it's back. Have there been any troubleshooting advances for this issue in the past two years, or do I need to go digging for the 3 year old firmware that worked? (Or just switch over to the Voxel firmware)?
    • FURRYe38's avatar
      Lets try some trouble shooting first.
      I haven't seen this issue since it first appeared and it WAS fixed way back then and hasn't been anyone else posting about it since either.
      Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
      Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
      Turn off and unplug modem.
      Turn on computers and rest of network.
      I recommend that you manually download the FW files and apply them manually with a wired PC and web browser to the RBS first then RBR lastly.
      Then factory reset the router and setup from scratch. A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
      I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON the ISP modem and let it sync. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC and a web browser.
      Press the back reset button for 15 seconds then release.
      What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
      https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
      • SidewinderX's avatar
        SidewinderX
        Guide
        Hey -- I currently have the latest (2.7.4.24) loaded, but it looks like the issue re-started when the router was on 2.7.3.22. (Which I never purposefully installed -- it seems like Netgear forced an over-the-air update without asking, which I don't really love).
        I'm fairly certain, from my previous notes, that part of my ultimate solution when this happened was to roll all the way back to 2.6.1.40, so I'm guessing I'll need to end up doing all of that again :(. Annoyingly, the release notes for 2.7.3.22 seem to indicate that that release fixed the DNS issue, so I'll probably retry that one again and go from there.
        Re: your other questions -- yes I've done the hard restarts (at least once a day now to recover the network). I've checked and confirmed traffic meter is disabled, I've checked the daylight savings time settings, I've experiemented with both Cox's default DNS servers, and then also used Cloudflare / Google DNS as well, no luck.
        My modem is a Motorola MB8600 DOCSIS 3.1 cable modem, operating on Cox.
    • CrimpOn's avatar
      CrimpOn
      If my WiFi router had to be restarted several times a day, that would be intolerable. As it is, my RBR50 has been running firmware v2.7.2.24 since May of 2022 and is only restarted (a) when Edison treats us to a long power outage, or (b) when I am doing a crazy experiment of some sort.  Currently, it has been up for 75 days.  My DNS entries are set to 8.8.8.8 and 1.1.1.1 (an experiment I was doing and just "left it that way.")
      There certainly have been recent posts about various Orbi systems having "problems" that go away temporarily when the router is restarted, and it is not always clear what the cause might be.  In this case, I would first want to validate the assumption that the Orbi DNS resolution is central to the problem.  For example:
      • Set some device on the network not to use the router to resolve DNS.  I often point a Windows PC to a Pi-hole DNS server (another experiment) or set it to use Google (8.8.8.8) and/or CloudFlare (1.1.1.1).  If other devices on the network begin to have problems but that specific device does not, that would tend to reinforce the idea that Orbi DNS is failing.
      • When problems arise, before hitting the power, conduct some brief experiments, such as opening a command window and attempting to reach internet resources by IP address on the device that is failing. For example:
        • Try to ping Ford:  ping ford.com
        • If that fails, try this: ping  19.12.97.37
          If this succeeds, that also would be evidence that Orbi DNS is at fault.
      I stay with the Netgear firmware in order to participate in the community forum.  See no problem with loading Voxel's version as long as the directions are followed (loading up a specific version of Netgear firmware first, etc.) When I tried Voxel, it worked great and has interesting features.  If you try rolling back to an earlier Netgear version, I would expect to wake up one morning and find that it had updated to V2.7.4.24 again.
        SidewinderX
        Guide
        I did a factory reset of the system and so far it seems to be working OK (3 days without a forced reboot), so I'm cautiously optimistic this is working.
